During some testing with a Chinese chip amp of questionable integrity, I somehow fried Q4 and Q6 on my miniDSP 2x4.
The transistors appear to be labelled 1IJ (or 1lJ). I've looked over a few spare PCBs that I have lying around from other electronics, hoping to find these parts to harvest and re-use. I did find some that look very similar.
Questions:
1) Do I need the exact replacement parts, or are there other transistors in the same class that would be suitable?
2) If I do need the same parts, how can I get them? I've googled and cannot find any info at all based on "1IJ" or "1lJ" searches.
3) If I do not need the exact parts, what class of transistor is it and what are some common, compatible parts?
4) Do I have other options?
Thanks for any assistance.
Questions:
I know it isn't in miniDSP team's best interest to help me - if my device is fried, I might buy another one.
However, I simply cannot afford to replace this unit. Please help.
I can only assume that the miniDSP team simply doesn't visit here very often.
The alternative explanation is obvious, and disappointing.
So, that's it then. I no longer have a functioning miniDSP and I am offered no solution from the manufacturer.
Message received.
Message received.
Message received.
Sorry about that, you need to find these tables from more manufacturers (maybe you already did).
https://www.digikey.com/Web Export/...53/PDF/MCC_SMD_Marking_Codes.pdf?redirected=1
Better SMD Code Book, hope it helps.
http://www.sos.sk/pdf/SMD_Catalog.pdf
Thanks Scott. I could not find the part on either of those lists.
Am I crazy assuming that the minDSP folks know what parts are installed at Q4 and Q6 on the miniDSP PCB?
