Hi again
i have some big doubts. I just measured at anecoich room the frequency response of the compression driver + the horn. Due to, i was having some problems when i did the response at full range for this speaker (100-1200Hz with two 12MI100(beyma) and1200< with CD755ND(Beyma)+TD590Horn)
the problem is, i get way much peaks at high frequency.
I have a filter (FD212 Beyma) as XOVER(1,2KHz) plus an additional configuation that the filter allows of -7,5 db attenuation and a -3,5db @ 3KHz.
well my question is , is this measurement normal?????? I used a pink noise, filtered in the rang of 1Khz< .
Which can be the problem of this high peaks???
how can this be?? can it be faulty the CD?? or is it normal??
thx a lot for your help.
