How do I know at what frequency my sub is tuned to?
Here's what I did:
I ran tests in my sub from 10Hz to 20Hz, because I think that my sub is tunned around those frequencies.
From 10Hz to 13Hz, there was a decent amount of air coming out of the port (like a fan with three settings in the middle position), and the driver's excursion was a lot.
From 14Hz to 17Hz, there was a lot of air coming out of the port (like a fan with three settings in the max postion), and the driver's excursion was a lot also.
From 18Hz to 20Hz, there was a decent amount of air coming out of the port (like a fan with three settings in the middle position) , and the driver's excursion was minimal.
From 25Hz and up, there was almost no air coming out of the port, and the drivers excursion was normal.
Here's what I did:
Joined 2003
The speaker should have the least excursion at the tuning frequency. It is hard to tell this from just looking at it and playing with a function generator. If it is a commercial product, look it up on the net, and you may find your answer.
The question arises, why does it matter?
