Freezing Points Of Gelatine And Other Additives In Water
Aengus said:
Try rowing - better exercise and easier on the body (note that I don't say easy, just easier).
Just getting over a back problem caused by a minor car accident and subsequent strain. This caused the cessation of my walking regimen, which caused an increase in weight, which caused knee pain when I went back to walking and then stationary bike, etc etc.
So rowing might not be the best exercise right now. However, the back is getting better, and when it is completely healed-it is not bad now-I will give a rowing machine a shot.
Things are not as bad as they seem. I put the icebags on my knees last night,and my legs feel better already. I have no doubt that a few sessions with the ice bag and I can resume the exercise regimen I had. When I do resume it, I intend to put the icebag on after every session as a way of preventing pain from building up in the first place. So I just want to streamline the icing or cooling process a bit, which was becoming unmanageable.
Aengus said:
If you want to put large cubes into a waterproof plastic bag, kayak supply stores will sell you drybags, which can be had with a large mouth (no comparisons, please) which has a watertight seal.
Aengus
Looks just what I need. Thank you, thank you , thank you. We have a lot of boating stores around here, so I will check this out tomorrow.
PS: Why do they call them drybags if they are suitable for icewater?
Didn't see this post, just wanted to mention one mythbusters experiment... they looked for the quickest way to cool a can of beer.... and it was by submerging it in a mixture of icewater and salt...
As for pain management.. I find ice a strange choice... heat I can understand, as the chemical messenger that carries the heat message in cells, blocks the chemical messenger for pain which is released when cells are dying or damaged....
Why do short people passengers move the seat forward in the car?
I can relate to the vicious back/exercise/weight circle thing. Attack the blood pressure through food as well.
Send a PM for my buttered bacon and fontina cheese sandwich recipe. Remember, Whisky has zero carbs and fat.
kelticwizard said:
.... I walk and also have begun to ride a stationary bike, and the bike causes strain on the upper kneecap and above...
Pain above the knee is a sign that your saddle is too low. You also may want to try shorter crankarms if possible, to reduce the range of motion of your knees.
Max
My purely empirical answer to the ice thing is to consider ice-cream machines (the domestic, non-refrigerated kind). They almost invariably use an ice/salt mixture, so I guess that's been found to work best in practice - and corresponds with the findings quoted by Nordic.
Nordic said:
As for pain management.. I find ice a strange choice... heat I can understand....
Nordic:
A friend who ran cross country in high school gave me one of his books, so here is the explanation circa mid 70's. Whether it has changed or not, I don't know.
Pain comes from swelling-sometimes the kind of swelling that is not visible. When a muscle is hurt, prostaglandins are released in the area and they just lay around, causing swelling and pain. When you first apply cold. in the first six minutes or so your skin will turn white, (assuming you are not dark skinned in the first place), because blood is not flowing in the area. However, after six minutes or so a reaction kicks in, blood comes gushing into the cooled area and your skin turns deep red. This onrushing blood has the same effect as a high pressure fire hose cleaning out a tunnel, and the prostaglandins get flushed away. As a result, swelling subsides and pain ceases.
Over the years, cold has worked on aching joints in a way that heat could not approach.
Not a bad idea. I thought about it myself, and the semi-frozen dessert might well be ideal medium for the therapy.
Only problem is that the whole idea of this exercise thing is to get the weight down, and I am not sure a brand new ice cream maker in the house will serve that purpose very well, even if I manage to refrain from consuming the medium which just cooled my knees.
poobah said:
I would be worried about frostbite with salt in the water!
So was I.
I put the mixture according to the proportions SY gave for six hours. Freezer temp: 12 deg Fahrenheit. Saltwater temp in icebag: 16 deg F.
I applied the icebags to the knees dry. After a few minutes, it seemed a little too cold to bear, so I put a dry towel, single thickness, between the bag and my knees. This allowed little cold through, so I got rid of it after a minute or so.
Total time bag was on knees: 24 minutes
Total cooling time: approxiately 21 minutes.
After I put the bags back directly on the skin, there was no sense of being too frigid.
At the end of the session, (21 minutes), the water temp in the one quart bags was 42 degrees. Which seems a little warm.
The knees seem chilled, they are red, which is good. I don't get the sense of a really deep chill I get from icewater. Perhaps putting a wet towel on the knees when using saltwater will improve things.
Conclusion: Putting salt water in the bag and applying the bags to the knees dry is somewhat effective, but not as effective as the icewater. However, there are things to try which might improve the method.
I was worried about it, too. Especially when the temperature of the saltwater was 16 deg F. I think I tried saltwater in the plastic food storage bags years ago, and it was too frigid to apply to the skin.
I think the latex coated fabric probably does not conduct the heat or cold as well as the plastic bags I was using, so the full bite of the cold saltwater doesn't get transmitted.
Alright, here's the story as I understand it from my experience with such things.
The extra cold salt water is certainly easier to manage but only does as good of a job as the ice if you are continually changing out the liquid over the treatment time to maintain an optimum temperature.
The ice water is by far and away the best treatment option as it maintains the optimum treatment temperature for a long time. The larger ice cubes are preferred over the smaller one as they won't melt as quickly (may or may not be a problem) due to less surface area exposed to the thermal transfer medium (the water).
Ice is still the preferred treatment option for the first hours after an injury as it does indeed reduce swelling and causes a few other things to take place also. If after the first 24 hours (there is some debate over this, I've heard anywhere between 12 and 48 hours but 24 hours seems to be the most widely accepted and also a reasonable compromise) there is still a need for treatment you then switch to treatment with heat.
Hope that helps.
