freeDSP main thread
Hi CyberPit-San,
thank you for taking the time to answer in such a detailed manner! I've read your answer and also some more of this thread. It seems that others have started with a commercial board based on the ADAU1701, before then moving on to building one of the custom boards. And looking for the chip name on eBay or AliExpress yields quite a lot of different boards.
What appeals to me is three-fold: being able to change the output sound from a software, the small size of everything (as compared to my 1990s Yamaha stack), the possibility of keeping everything digital (I2S from the PC right up until the amplifier). Since my speakers are quite benign (a pair of 50W Quadral bookshelf speakers and a pair of 125W Klipsch floorstanding speakers, usually driven rather quietly) I'm thinking to get myself a Wondon JAB5 + cabling set + HDMI I2S extractor + programmer for Christmas. One question about the programmer, as it seems there are three. Between the Sure Programmer, the Cypress and the Free USBi, which one should I get, or does it not matter much?
Best
Jonathan
Hi Jonathan-San,
Well, you can find various ADAU1701-based boards at AliExpress. Also, the ADAU1452/1466 daughterboards are available. So I built an ADAU1466 Full digital Pre-Main Amplifier for my main system. It sounds really good with full digital processing capability.
CYberPit ADAU1466 + TAS6422 Full-Digital Amplifier
(Sorry, My web page is written In Japanese)
Wondon JAB5 looks like DaytonAudio KAB4100. I'm not sure, but those are almost the same profiles. Those products have a proprietary configuration header which is different from the USBi 10P MIL header. Finally, you need to buy Sure Programmer (or Dayton Audio KPX) anyway.
CyberPit
Thanks to everyone. Many people had interested in FreeDSP-related products and activities.
Exhibition Snapshot
CyberPit
I stumbled across freeDSP and think I have a use case I'd like to dig in deeper.
I have a 2 channel stereo home recording studio where I am using Sonarworks software for room correction. I was thinking about a dsp solution to offload the room correction processing from my CPU.
I am looking for a digital in and digital out solution. I dont want to add a layer or modify my current AD/DA conversion path. I leaning towards AES/EBU in and out. I need the ability to manage sample rates from 44.2kHz to 192kHz. Id also be looking for minimal latency between the in and out.
Can any provide any thoughts or point me in where to direct my research attention?
Hi txshonk
You are writing Sonarworks and Room correction .... but is Sonarworks room correction or "just" speaker correction? From their web page I think it is the last.
With something like freeDSP you can readily correct a set of speakers, working on especially frequency response.
Room correction is difficult, but can be done with e.g. Dirac SW which could run on the more capable freeDSP implementations if we had the right interface, which I believe we don't. But it is done in a similar HW by MiniDSP.
But for a recording studio I don´t think this is actually what you want. In a studio you would make proper acoustic room treatment to make the room behave well, and you would use speakers which is fairly neutral. Speaker correction is for sure a good thing in such setting (as in all settings), to get a neutral in room response. Use REW to measure response and SigmaStudio to insert the needed freq response correction. 2 channel in 2 channel out can be done with a ADAU1701.
Hello txahonk-San, Baldin-San,
If the ADC/DAC is not required, ADAU1701 is not suitable for this case.
ADAU1701 has only I2S and embedded Codecs. Additional cost for DIR/DIT equals more than the upper version SigmaDSP. So, If you want to connect with only digital I/O in various sampling frequencies, you'd better choose ADAU1452/1466 board such as follows...
MusicWorks ADAU1452/1466 Core Board
This board plus USBi or compatible configuration interfaces need such as FreeUSBi or something like that.
CyberPit
Hello everyone,
I'm using ADAU1701 board in my DIY amplifier/speakers setup, and it's great.
To program ADAU1701, I use CY7C68013A board, and it's also working fine on my old Windows laptop, using SigmaStudio. Many thanks for people who made this possible.
However, as I am using macbook with M-series chip in it, having another machine (and in my case - much slower and older) only for this purpose is not very convenient.
So what I want - is to use SigmaStudio on virtual machine, such as Parallels, but there is an issue with freeUSBi drivers - they are not available for ARM architecture.
Is there a possibility to get freeUSBi drivers for Windows 11 ARM? Or probably there is another way to accomplish this?
Solved an Issue on FreeUSBi
I faced an issue using this EZ-USB FX2LP CY7C68013A _DevBoard with my FreeUSBi board.
Schematic(Not sure)
When I stacked the FreeUSBi Board, the FX2LP CPU did not boot. As a result of this, there are no USB bus resets.
So I cut a line 1 by 1. Finally, I found the SDA line of I2C voltage dropped some.
I needed to change the schematic circuit like this...
The voltage-shifter control line, which is labeled "USB_PWR_ON," has its voltage kept Low at the USB connection. Because the uP is not run yet.
This line should be High at the beginning of the USB bus reset.
I made some modifications to my version 0.41 FreeUSBi
Now I update my FreeUSBi Git-Hub Page
https://github.com/CyberPit/FreeDSP-FreeUSBi_Programmer_hybrid_version
Version 0.5 is the latest design.
CyberPit
