freeDSP CLASSIC help
The ADAU1701 supports I2S or TDM interfaces; you could use this to connect to an external DAC or two. There must be something suitable you can get on eBay, an extra 2 audio channels should be easy but with 4 audio channels you would need to split LRCLK/BCLK if using 2 channel DACs. Just a case of setting it up in SigmaStudio then.
