Hello,
Like new and free in its original crate.
https://nsa40.casimages.com/img/2020/04/17/200417124146447803.jpg
https://nsa40.casimages.com/img/2020/04/17/20041712414826666.jpg
* 1400 watt continuous program power capacity
* 100 mm (4 in) copper voice coil
* 30 1000 hz response
* 95.5 db sensitivity
* double silicone spider w/optimized compliance
* nominal diameter 460 (18) mm (in)
* nominal impedance (1) 8 ohm
* minimum impedence 6.3 ohm
* nominal power handling (2) 700 w
* continuous power handling (3) 1400 w
* sensitivity (1w/1m) (4) 95.5 db
* frequency range 30 - 1000 hz
* voice coil diameter 100 (4) mm (in)
* winding material copper
* former material glass fibre
* winding depth 21 (0.83) mm (in)
* magnetic gap depth 10.5 (0.4) mm (in)
* flux density 1.05 t
* thiele & small parameters
* fs 30 hz
* re 5.3 ohm
* qes 0.41
* qms 4.6
* qts 0.39
* vas 245 (8.6) dm3 (ft3)
* sd 1210 (187.6) cm2 (in2)
* eta zero 1.6 %
* xmax +/- 8 mm
* xvar +/- 8 mm
* mms 202 g
* bl 22.5 txm
* le 2.1 mh
* mounting & shipping info
* overall diameter 460 mm (18 in)
* bolt circle diameter 440 mm (17.3 in)
* baffle cutout diameter 422 mm (16.6 in)
* depth 197 mm (7.75 in)
* flange & gasket thickness 16 mm (5/8 in)
* net weight 10.5 kg (23.1 lb)
* shipping weight 11.9 kg (26.2 lb)
* shipping box 500x500x250 mm
* (19.7x19.7x9.8 in)
* fs 30 hz
* re 5.3 ohm
* qes 0.41
* qms 4.6
* qts 0.39
* eta zero 1.6 %
* xmax +/- 8 mm
* xvar +/- 8 mm
* mms 202 g
* bl 22.5 txm
* le 2.1 mh
A-ehm...I'm the first !!
Am i???
Hello, why not !
The shipement cost is :
28,55 € for the France
61€ for the EU
73.6€ for the world
Am i???
those things aren't exactly pico...
Alors je prends !
Si toujours dispo bien entendu
"Une personne anonyme" m'a envoye un MP discret... faut pas que cela s'ébruite sur le forum, il a peut être honte.
Tu est donc le N°2 tant qu'il n'a pas répondu en MP.
Traduction : A French guy have made me a proposition in a private message.
And he answered !"Une personne anonyme" m'a envoye un MP discret... faut pas que cela s'ébruite sur le forum, il a peut être honte.
Many thanks for your generosity
Guillaume
Hello,
The "french guy" is the winner right now, he has proposed to resolve all the shipement formalities by itself in sort that i've nothing to do.
Sorry for the foreign people but there are 10 pages of documents to fill and it takes hours, the french people are priorized, and i know that is injust.
Shuuut
Shipement for the world outside of the EU :
Eastern European countries (excluding EU), Norway and Maghreb : 73,60 €
African countries (except Maghreb), Canada, United States, Russia, Near and Middle East : 168,00 €
Sorry for those who are far from France, this loudspeaker driver unit is really great for the price
And he answered !
Guillaume
Shuuut
Silverprout you have PM.
Hello,
I'm waiting for "guyome" instructions concerning the shipment, but it cost 73,60 € for your country without any insurance.
Just out of curiosity: is there now export paperwork in France for private / personal shipments to other EU countries? The last time I sent something from Germany to Slovenia, there was absolutely zero paperwork.
Because someone have done it for you, with the international shipment of my country post service all the declarations have to be manually signed in 3 exemplaries.Just out of curiosity: is there now export paperwork in France for private / personal shipments to other EU countries? The last time I sent something from Germany to Slovenia, there was absolutely zero paperwork.
