Free (Australia) - Amp modules and DC power packs
I will cover postage in Australia only and is for all items as a bulk package. If there are items you don't need, just pass onto someone else.
* Dayton DTA-2 amp module which uses the TA2024 like the old Sonic Impact of yesterday. Needs a 12VDC (max) 2A power supply and is wired as a power amp but the volume and switch is included. Just swap over at the connector. https://www.daytonaudio.com/images/resources/300-385-dayton-audio-dta-2-user-manual-revised.pdf
* TPA3116D2 amp module which needs a 12VDC 2A to 24VDC 4A power supply.
* TPA3116D2 amp module with volume control and 3.5mm input socket. Same power requirements as above and this one has a bit of hiss. I turned the volume to max and adjust the volume at the source.
* 24VDC 1A new linear unregulated power supply (33.4VDC no load). Not suitable for the above amps and needs regulation for most circuits. 2.1x5x11 + pin.
* 12VDC 300mA new linear unregulated power supply (17.9VDC no load). Not suitable for the above amps and needs regulation for most circuits. 2.1x5x11 + pin.
