Banned
Joined 2002
Banned
Joined 2002
B1060’s? Is that MBR1060 diodes? 10Amp, 60Volts? What’s your transformer secondary? Could it be that you are running them at too high voltage? There really shouldn’t be any need for such a big sink. I recommend you try some mbr20200 if your mind is set on schottky rectifiers. Or since you already have 8 of them try using 4 for each secondary, reducing the voltage and current the diodes have to deal with.
Out of curiosity, the hum you had, was that from the speakers or from the transformer? When I replaced the standard bridge rectifiers in my amp with mur3060 and rc snubbers I experienced a huge improvement in transformer noise. With just the standard bridge I could hear the transformer humming from a few feet away, but with the mur3060’s I hardly hear any transformer hum, even with my ear right up against the transformer.
Banned
Joined 2002
JasonL said:all my money just went into my new APPLE 17" POWER BOOK : O )
I think that's the real problem!
Banned
Joined 2002
Hey~!! You could get free MUR860s here...
www.on-semi.com
Fill up the registration from and search for the part...hit the samples buttong and checkout...
get 50...of those for free...
www.on-semi.com
Banned
Joined 2002
when i click on yur link i get this
http://in.netster.com/Index.asp?Site=b24tc2VtaS5jb20=
and tons of popup's
and tons of popup's
Banned
Joined 2002
JasonL said:when i click on yur link i get this
and tons of popup's
It's actually this: ON-Semi
Zach
Banned
Joined 2002
Kermit said:Well, there’s your problem.. that’s waayy to much for those diodes. As a rule of thumb use a diode that has a PIV of at least twice the worst case peak AC voltage.
Peak voltage where and how ?
Could You elaborate a little on this as I'm tryinmg to do some dimensioning of discrete rectifier diodes ?
Best Regards /
- FREDS HOT
