This seems as good a place as any for this question as they are mostly used here. Is there any spreadsheet other the Excel which will run these spreadsheets. My computer which had microsoft office on it has wrecked the hard drive and I do not feel like buying the program again to use in my other computer. Thanks for any help.
jamikl
jamikl
Why do you think you need to buy the program again for use on a different computer?
That's often how software licenses work.
@jamikl: Have you tried Open Office?
LibreOffice has limited support for VBA. It won't run the macros in PCD, WBCD, Baffle Diffraction or the Frequency Response Modeler.
The Woofer Box and Circuit Designer (WBCD) was "converted" to .NET several years ago. The .NET version has evolved separately, but it still uses the same Benson model that Jeff Bagby implemented in his original Excel version. Converting the Excel equations proved to be a laborious task, so I wrote completely new versions of PCD, Baffle Diffraction and Frequency Response Modeler. They are implemented differently but should provide the same results. Part of the new design approach was to integrate these tools into a single program, where calculation results from one module are passed along to the Crossover Module. This results in an easy-to-use integrated tool that does measurement file processing, Box modeling, Baffle modeling, Amp/EQ modeling and Crossover Design.
This integrated program is PSD-Lite. It is still a Beta release but it is fully functional and reasonably mature. The final version is getting a Thiele-Small database--it will be available soon.
PSD-Lite can be downloaded here: http://www.audiodevelopers.com/Software/PSD_Lite/setup.exe
This version of the program is free, and it will remain so. There is a "Pro" version with more features and an "Active" version that can directly control DSP chips.
Neil Davis are you saying that PCD lite will run with Libre Office. I have tried the others with Open Office, Gnumeric and the spreadsheet in the Ashampoo office set =- all to no avail. I lost the copy of MS Office I had when the hard drive failed and didn"t have a copy of it - must have lost it in a house shift about 18 months ago. As I am on a basic Australian pension some of the programs which may be cheap to others are quite expensive to!. I thank you all for your help.
jamikl
jamikl
PSD-Lite is a .NET click-once application. No Excel or Office of any sort required. All you need is .NET 4.0, and the installer will take care of that for you.
- FRD and other Jeff Bagby spreadsheets
