Prym Consumer USA Inc. | Product Spotlight
If you follow the link to the Fray Check FAQ near the bottom, it pretty much says this is a Nylon in Alcohol formula.
Anyone reckon this would work as a ready-mix coating for DIY panels?
It is widely available, relatively cheap (dependent on coverage in this application) and even on ebay
Next time I go out I will see if I can get some.
Their website says that it should be available in my area.
jer 🙂
jer 🙂
Alcohol soluble nylon is widely used by tailors as a strong hot melt glue. Already tried the one in a form of non-woven fabric glue stripes. Better check before you going to buy reasonable amount. It well might be non-woven PET with some acrylic glue.
http://store.quilting-warehouse.com/notions-adhesives.html
"Another type of fabric adhesive is iron-on bonding fabric, sometimes called fusible web, a layer of adhesive material placed between two layers of “regular” fabric to fuse them together permanently" (c) wisegeek
