I know this may make no sense but seems to sound better than without the small plastic tube?
I misread that at first. So the tube is better than no tube.
The longer the tube, the lower the tuning frequency, so you may be hearing a touch more bass.
If those are external dimension and the wall thickness of the cabinets is 15mm, then the internal volume would be around ~16.75 liters, and maybe a little less than 16.5 liters are taking into account the driver magnet, port etc.
It’s easier to use a 3” diameter tube because that’s the size of the hole.
8’ long,long enuff you might get some vent resonances, but the recomended damping in the vent will largely tame that.
dave
3” D x 8.5” long, add some dampinmg.
dave
- Full Range
- Frankstein full-range drivers speakers - what have I created? Why does it seem to work?
