• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
FR88EX
I want to recommend one full range driver named FR88EX here.🙂
The motor is an underhung neodymium design and the cone is thin (and fragile) formed aluminum. The only negative is a slightly ragged top end that may take some filter work if used full range, but I'd generally recommend a cheap and small neo tweeter placed close and crossed over high. There's a lot on the positive side, like high sensitivity, a clean low end and smooth midrange response. The frame is cast with ventilation under the spider, but users will have to pay close attention to airflow behind the cone - It's even more important to chamfer the inside baffle opening and in this case likely use a thinner baffle material as well.
More details pls see Products_Fountek Electronics Co.,Ltd
Any further help pls contact:
Evan
E-mail:evan.zhu@fountek.net
MSN:Fountek_Evan@hotmail.com
Thanks Evan - looks like an interesting driver.
I have a friend who will be using this in an open baffle design with an 18" woofer under it.
The design may be posted on diyAudio if it works out.
Great speaker. Here is what I built.
