FR125S + Tripath 2020 Charlize, am I crazy?
I've been thinking of what to pair my (as of yet) unfinished FR125S's with, and I've been considering toying with the Tripath Class D 2020 amps lately... 13W into 8Ohm, but more like 8W with any reasonable degree of THD.
Am I crazy if I want to get any reasonably loud sound out of that?
I've plugged my Hales Revelation 1 (87dB) into a Sonic Impact, and in my opinion the SI amp is not at its best when paired with a less sensitive speaker. My Pass Aleph 3 (30wpc) sounds much better juicing the Hales--more dynamism and more presence.
Of course, this is an unmodded SI. A tripath chip could work better with the right implementation, but I haven't gone down that road yet.
Randy
I have a TA-2020 which I never use above approx 8 watts for a reason you already know. I use the TA-2020 with a pair of Jordan JX92S in TL enclosures. The sensitivity of the Jordans is about 86dB. My listening room is 5.5 x 9 meters.
I usually play at a sound level which requires raising your voice just a little. This combination works excellent.
If you decide to use the TA-2020, I recommend using the TA-2020 evaluation board as a starting point.
