OK, thanks, i thought it was a different type/make of DSP perhaps at a better price, if one has, say a 3 way, this is still quite an expensive pack isn't it?
MiniDSP makes a number of models....I'm using the basic MiniDSP 2x4, about $95 at MiniDSP or $105 at Parts Express
The next one up is the MiniDSP HD 2x4 about $200....has optional (inexpensive) remote, higher output voltage, and is also essentially a USB DAC
and they go from there.....The Linkwitz LX-mini uses the above DSPs as some options all the way up to the MiniDSP 4x10 unit.
Many thanks for that info, are there inexpensive good quality amps to match please, whetehr built or diy?
Did this brand corner the market or are there alternatives/
many thanks, mike
many thanks, mike
I am using 2nd hand HT receivers, the older ones usually have 5.1 or 7.1 analog inputs. These are cheap, offer a main volume control and most of the times a level setting per channel, which can be used for adjusting the sensitivity of the different drivers in your speaker.
I got a Denon 3801 and a Arcam AVR300. The Arcam does have better audio indeed, but it was something as 250USD, while I got the Denon for 50 USD.
for the DSP, besides MiniDSP there is also this unit from Dayton audio. It is basically two of the 2x4 MiniDSP in one box.
Dayton Audio DSP-408 4x8 DSP Digital Signal Processor for Home and Car Audio
