In case anyone is interested in (potentially) better than average in-wall loudspeakers, take a look at this:
Fostex NetCIRA SI-1
These retail at under £100 each in the UK. I've spec'd some on a project and will take a listen when they arrive.
The drivers look a bit like the FE-sigma range....
I quite like the idea of having these installed in my bathroom or kitchen 🙂
Fostex NetCIRA SI-1
sharpi31 said:In case anyone is interested in (potentially) better than average in-wall loudspeakers, take a look at this:
Fostex NetCIRA SI-1
that seems a bit rich for a ceiling mount, until you look closely:
they certainly do
might want to research tolerance for humidity in those locations, but could certainly make for interesting in-walls for HT .
sharpi31 said:The drivers look a bit like the FE-sigma range....
Actually those would be from the HP series. I've not seen a FR before, usually they need a tweeter.
Can't find the 2 drivers that were available to diyers anymore on Madisound or Fostex site... they are like the extended range in these.
http://www.fostexinternational.com/docs/pro_products/nx6a.shtml
dave
also note from technical specs:
Speaker unit: 13 cm HP diaphragm full range speaker unit x 1
Frequency response: 80 Hz ~ 20 kHz
Impedance: 600 / 1 k / 2 kohm (harmonica terminal switching type)
Rated input: 16 W (600 ohm), 10 W (1 kohm), 5 W (2 kohm)
These are clearly designed for (high end) commercial background music/PA - i.e. they would require some form of distribution transformer to couple to conventional audio amplifier.
Note there is even a ceiling mount enclosure for a horn loaded version of the same driver -
http://www.netcira.com/docs/products/si1h_tech.htm
along with more measurements than you normally find for their "audiophile / DIY" drivers.
They are available with and without transformer. So for hifi, don't buy it with transformer and you'll get a hifi-impedance i guess.
Also take a look at that really nice 6,5" coaxial, that one is about 25 Euro.
-Micha
