Fostex Fe204 in Jordan VTL?
Hi!
Have anyone here seen this before, a Fostex FE204 in a Jordan VTL cabinett. Does that work or is it most likely to be a missfit?
I like the design of the Jordan VTL and it would be possible to use in my livingroom.
Any Ideas around this?
The cabinett with fe204 has twice the volume.
Original has an outer volume of 28liters and fe one has 56liters outer volume.
I have calculated only on the total size of the cabinets.
At a glance, gross volume assuming the same 1.8 cm material thickness will need to be ~65.83 L. Assuming the Eikona VTL is tuned to ~Fs, then scaling width and/or depth is required to keep ~ the same TL path length, otherwise best to design from scratch using actual measured specs.
GM
