This is a rumble and not a ground problem? Motor and mechanical problem? I have a Systemdek IIX. I know this is not a "top fo the line" turntable.
dunno Bro .... if you have a turntable , you need to know difference between hum and rumble
we can only guess , except in case that you post one nice video with decent sound , so we can judge by facts
... since 25 years I move from analog to digital... in this era I listen vinyl on Oracle... I never sell my vinyls (1000). Today I try to re-listen my collection and I re-discover many smalls problems affect vinyls listening.
Thanks for your response... I begin my quest to find a more "rumble" free turntable.
hold on
that was just an idea/question ...... not conclusion
investigate first , then think what's next
Does not seem like rumble. This problem may be due to the cartridge. Does the hum get louder
as the arm approaches the center spindle?
No. I try 2 differents cartridges and the "rumble" is similar. Also, I note the "rumble" is more intense at the beginning of the record and is less audible near the spindle at the end of the record.
This "rumble" sound increase at the same level when I increase the volume.
Does the bottom of the cartridge ever touch the record, like on a warp?
Does the bottom of the arm ever touch the cue bar when playing (near the back of the arm)?
Is there still noise when the arm is on the record, but the platter is not turning?
No
No
No, but I'm trying this. Needle on the record, platter don't turn. No noise. I start the motor and the sound begin slowly and he reach expected level when the motor reach it's normal rotation speed. It's appear this is a friction problem...
No
No
Now leave the power off, remove the belt, spin the platter (in the correct direction!) by hand,
to roughly the right speed, cue the stylus on the LP, and listen. Is there noise now?
If there is noise, perhaps it's the bearing or suspension. If no noise, perhaps it's the motor or belt.
Wow. Rayma you are a genius. No noise when I spin the record manually. It's appear noise is generate by the motor itself.
Now... How to solve this problem? A faraday enclosure around the motor or simply replace the belt?
No noise when I spin the record manually. It's appear noise is generate by the motor itself. How to solve this problem? A faraday enclosure around the motor or simply replace the belt?
Is the noise more like hum, buzz, scraping, etc? Take a good look at the belt, pulley, and platter drive surface. Also some cartridges are unusually sensitive to AC fields, try another standard sort of cartridge with good shielding (Shure, etc). Also make sure the tt ground wire works by disconnecting it, which should make a lot more noise.
I do have some mu metal if worst case. However, if it were the motor, the noise should increase toward the spindle, which you said was not the case, so this is not proven.
with belt still removed , put record on platter , place needle on record
power on motor , power off
try to conclude - is hum there while motor is powered , or hum is there while motor is still spinning , even without power
if latter , hum is mechanical , not generated by flux
if not later - hum is generated by flux
Forgot this important test:
Remove belt. Turn on motor. Spin platter by hand and cue the stylus on the record.
Is the noise there now?
Hi all,
Sorry for the delay (long night in Montreal).
@ Rayma
The noise is audible hum. I clean belt with R2 and the pulley also. I switch my Acutex cartridge (LPM 315) for a Shure (M97ex). And the hum is always present. The ground is ok. Effectively, the sound is less audible near the spindle.
@ Zend Mod
I try all of suggestion and the noise is only audible when the belt is in place and the needle is on the record and the motor is on power. The problem appear to be "mechanical".
@ Rayma
No noise.
After all off the tests you propose, I note a small vibration inside the motor itself... I investigate on this way. I expect now this is not a flux problem but a mechanical problem.
I dismantel my TT this weekend and I investigated.
Many thanks to everybody.
@ Rayma
@ Zend Mod
@ Rayma
No noise.
... Thanks for your response... I begin my quest to find a more "rumble" free turntable.
What Oracle do you have? I have an Oracle Delphi, and there is never any detectable rumble at all. I have played poorly recorded records that exhibit unpleasant low frequencies and rumble, but never rumble from the turntable itself.
I previously had a Music Hall 9.1 that picked up resonance from the speakers when the lid was down (it wasn't stable when left in the up position), which was also amplified through the carbon arm. Your Oracle should be pretty immune to rumble, but if you also put the cover down when playing records, try keeping it in the up position.
However, if you still suspect the turntable is the source, you don't need to find a different turntable in my opinion. Instead, pull the platter and inspect the thrust plate on the bottom of the spindle bearing, the ball bearing on the tip of the spindle, and check the oil level. If it's empty or the thrust plate is bad, you'll get rumble. Also inspect the belt, however, I can't imagine a belt in poor enough condition to transmit noise to the platter would not have broken by now.
- Forte' audio model two preamplifier
