HiFi Mono Full-Balanced Unalloyed Power Amplifier L&W X-1 Bridge Connection BTL 600W Home theater Pure Aluminum Radiating
Description:
Item Type: L&W X-1
Power Output:225W(8Ω) 、450W(4Ω)
Bridge-Mono Power: 600W
Transformer: 700W
Frequency response range:10Hz-80KHz(+1/3dB)
Damping Factor: 400(100hz, 8Ω load)
Input Impedance: 20KΩ
Distortion:≤0.01%(1kHz、1W)
Power Voltage: 220±10%
Dimension: 215mm*145mm*394mm(W*H*D)
Net Weight: 11kg
Gross Weight: 12.5kg
FEATURES:
1. The overall adopted integrated circuit board design, optimize the circuit and find the shortest direct. Completely eradicate multi-chip circuit board affect the sound quality and impedance.
2. The capacitance is 48000UF each channel and 700W independent toroidal transformer, each channel output 8Ω 225W, 4Ω 450W independent module transformer-less,
3. Sets of x-1 can be bridge connected to 600W of the full balance output power under 8Ω loading.
4. Hand-made 5pcs toroidal transformer power(import from Japan) supply a large amount of electric current, even when confronting some low-efficiency speakers or big fluctuation music and movie part, x-1 can still output a large amount of current to ensure the normal performance.
5. The upper apex of the heated area is made of pure aluminum, the special material in the side can effectively eliminate the rebound rate to the greatest extent reduce the resonant frequency, decrease the distortion of sound quality, make the sound more clear and delicate.
More information, please visit the link:X-1 Mono power amplifier
Contact: Tracy Feng
Email: cqunfeng@outlook.com
Description:
Item Type: L&W X-1
Transformer: 700W
Net Weight: 11kg
FEATURES:
Contact: Tracy Feng
For Sale! AMP-112 Power Amplifier
Description
S/N(Signal to Noise Ratio): >105dB(A-weighting)
Frequency Response: +1/-3dB(10-85kHz)
THD+:≤0.05% (1KHz, 1W)
Output Power: 225Wx11(each channel tested independent, 8Ω)
350Wx11(each channel tested independent, 4Ω)
Matching Resistance: 4-16Ω
Supply Voltage: 220V±10%/50Hz
Power Consumption: 2500W
Weight: 48KG
Dimension: 430mm*250mm*460mm(W*H*D)
Features
1. It is the first multi-channel and overall external passive cooling system (to solve the problem of poor built-in heat dispersion)
2. All series are full manual and silver welding craft, no plumbum
3. Designed of ultra-low vibration and toroidal transformer
4. Customized non-oscillating and high-capacity capacitor
5. 11 channel and each has the 225-watt amplifier
CONTACT US
Tracy Feng
Email: cqnfeng@outlook.com
729598844@QQ.com
Address: Panyu District, Guangdong Province, China
More Information, please visit our website: AMP-112 Power Amplifier
Description
Weight: 48KG
Features
CONTACT US
Tracy Feng
729598844@QQ.com
Threads merged. Please restrict all commercial sales to this single Vendor thread.
RULES
COMMERCIAL SECTOR AND VENDORS BAZAAR RULES
These rules apply to any members of our commercial sector as well as anyone promoting anything on diyAudio. Repeated violations of these rules will result in termination of your account and all your threads without hesitation.
- No promotion or sale of products infringing trademarks, regardless of the country of origin of the trademark.
- Only one thread per vendor in the Vendors Bazaar
- No thread "bumping" in the Vendors Bazaar
