For purists wanting minimal PC config: Dos based MPXplay
Thank you for this information Yves - I visited their web site (and others) to check this program out and found a lot (to much?) information. Looks as if sorting through all of this info will take a good bit of time. Now where did I stash that old computer that I was saving for a project?
You're welcome.
It can be hugely tweaked - Actually this project is running since '99, I was doing a test build with it for car audio back then, booting DOS of a CD changer at that time (multi gigabit storage was a no-no back then 🙂
I even was able to put together a 4x20 character LCD screen on the parallel port. Everything was running on a downclocked Pentium 100 and running perfectly (MP3's VBR back then)
It's a daunting task but I think it can be very rewarding with a minimal of hardware involved. I especially like the speed it operated at.
Using a numeric keypad only, I could change directories with / and *, and you can enter a track number immediately. This is very fast access to files.
Haven't worked with it in the last years, but looking at how purists here want to minimize background processes & such, and control playing from RAM and such, it's best to go back to a non-multitasking OS, using a program just to do the task at hand.
For testing purposes there is a win32 version to run under windows.
If you need DOS info, I'm an old skool IT consultant, I'd be happy to help.
