foot switch safety question
Hi, I am planning on adding a bias switch (cathode/fixed) on my foot switch as have an open hole.
Is this safe? I have -50v running down the line. I also would like to connect the resistor and bypass cap in the foot switch to ground. But in another amp I have that resistor gets really hot.
Here is a drawing:
Thanks,
Daniel
Do you really really want to run all your signal through a foot switch, 3 meters outside of your amp? Remember, the cathode is a signal input too. I m sure you would not like to bring all the electric interference it your powertubes. How about a relay?
If that resistor got hot, it means it is under rated. Replace it with one that's like 5x the wattage dissipated in that point.
Thanks Costis, that's why I asked. I didn't know what it would be like to do that. Does that mean a shielded cable wouldn't work either? There are other signals but they go to and from the preamp, is that different? I put the switch on the amp and I love it, I just thought it would be cool to have it as a foot switch option. Would it be the same if I ran just the cathode line in and out of the foot switch and back to the amp to ground it there?
I will change that other resistor, thanks...
Good point Wave... issue settled, I won't do it. Thank you
I have use for another boost switch- one for each channel, so that's what I'll do instead.
I'm sure glad I asked!!
I have another post concerning the amp I mentioned that gets hot in the cathode resistor, would you mind looking at the schematic and my description, for an opinion. I see you are a designer and tech and I would appreciate a professional viewpoint and any criticism or suggestions you may have.
Thanks again,
Daniel
Hi Daniel;
if the resistor dissipates fair amount of power it should be hot. Modern resistors rated for the same power as older ones are usually smaller in size, so run hotter. If it dissipates half of rated power (you may easily calculate it), it is fine, just place it such a way it has no less than 1/3 inch distance to other parts/surfaces for proper convection. Also, keep electrolytic capacitors farther from hot air flow from resistors: electrolytics die faster when heated.
For the subtle difference this switch makes, only my opinion of course, it doesn't seem like the kind of thing you;d switch on the fly anyway.
But were you to do this, instead of cabling all that stuff down to the pedal, leave it in the amp and add a DPDT relay to do the job. Then a single line to the footswitch to operate the relay makes the footswitch simple.
Enzo, thanks for your input. I guess I don't know how a relay works, but for now it doesn't matter, and you are right it probably wouldn't be a switch you'd use during songs. But I added this to the back of my Fender Concert Rivera and I was surprised at the difference it makes. It is much spongier in cathode bias mode and it gets a lot of woooaawooooaaw... kind of effect. (it's hard to describe that in words) I've opted for a boost switch on the input tube for both channels and a separate one for channel 2, giving that one a 2-boost possibility.
