Why are you trying to patch XP. It's time to move on. All of the problems with the XP mixer go away in Windows 7. As long as you set exclusive mode, you can get bit perfect output using Direct Sound. You don't have to screw with ASIO or WASAPI. But then, who cares about bit perfect. You are going to do all of your EQ within the player.
What is the concern about buffered output? Is your computer really that slow? Probably not. There is a lot of time and effort spend eliminating as many processes as possible on the presumption that it has to make a difference. There are a lot of people that are pretty sure that it is irrelevant, including me. I am pretty sure that if you have a reasonably modern computer running Windows 7, buffer size makes no difference in playback quality. I routinely run Thunderbird and Chrome while I'm editing files and there are no glitches in the playback.
Bob
Bob
My board and cpu are brand new: AM3 board by MSI and an AMD Regor three core cpu. I use only onboard audio.
Nothing to argue about. I will report back if indeed the performance tweak in XP was successful.
Bob, I bought the Parts Express DAC and a ART USB Phono Plus V2 Phono Preamp with USB. I have a question about ripping CD's. CD's are 16/44.1 and the DAC will support up to 24/192. But if I play a file ripped from a CD is it going to play at 16/44.1 or does it convert it up to 24/192. I think it will play at 16/44.1 but am a little confused about this.
Also where does a person get the 24/96 or 24/192 music from?
Does anybody know what bit rate the ART USB Phono Plus V2 is or do you set it in software somewhere when you rip a record or tape?
Kenny
Kenny
Here is clear, concise, step by step tutorial, for setting up a current state of the art music server. Written by Gary Koh, whose long term profession is in the IT world and whose lively hood is Genesis.
http://www.genesisloudspeakers.com/newsletter/Newsletter_10th_Anniv.pdf
Bud
Bud
For the record, you no longer have to paste the DLL's in the components folder anymore, just open up preferences in foobar and then components. At the bottom, it should have a button labelled 'Install...', click on that and navigate to your plugin.
Correct, actually I think that's the "supported" way now. It allowes checking for updated components.
