We are mostly using this now:
http://www.diyaudio.com/forums/css/150054-new-product-acoustic-insulation.html
dave
dave
One more option: I built Fonkens using Parts Express 0.5" Acoustic Barrier Foam with adhesive backing. I don't know how this compares in cost to other options, but I have used it in several projects with good results.
Cheers, Jim
Cheers, Jim
If you're really cheap (thrifty), you can raid old speaker boxes for felt. There was quite a bit in an old pair of Sansui's I found at a garage sale.
Jeff
Jeff
Jeff, the word is "frugael" 🙂 - if one is lucky, years worth of projects can be engineered around recycled materials, but eventually the local supplies will dry up.
the 1/2" Ultratouch insulation is very easy to work with - cuts like a dream, and the bonded fabric backing material keeps it from falling apart and it glues very easily with Weldbond
I hope this is not off-topic, but has anybody tried the Pioneer B20 from PartsExpress in Fonken cabinet ???
Given how well suited B20 is as a budget FE207 substitute, it is possible that it will work in Fonken207 (if it ever gets done, and i can make it work).
dave
dave
A standard fonken box? About 35L tuned to 53Hz.
Jeff
Nope -- that box is too big. I have a sim sitting here of 24 litre tuned to 52 Hz... (now i'm giving away some secrets 🙂)
dave
dave
Is that the same as: http://www.bondedlogic.com/ultratouch-cotton.htm for us in the States. Also how you achieve a 1/2" sheet, is it just split from thicker sheets, as you mention 3.5" to 8" widths available, just like Bonded Logic's Ultra-Touch Insulation.
Wouldn't mind discussing this with you on the weekend if there's time.
Jeff
Yes, that is what we use. They make a 1/2" version that is denser than the thicker stuff.
Minimum quantity is a roll -- ~400 ft^2 (ie 100 ft long roll -- enuff to stuff about 200 uFonken). This is why i usually point people at Bob. He bought a roll (and i got a significant portion of that for our use) and is selling much smaller quantities -- quantities suitable for diy speakers.
dave
Sure.
dave
My wife yelled at me for doing that the other day. Before tossing a pair of speakers I found in my parent's basement i grabbed the fiberglass fill and put it in a bag. She looked at me funny and I said "What? This stuff is valuable."If you're really cheap (thrifty), you can raid old speaker boxes for felt. There was quite a bit in an old pair of Sansui's I found at a garage sale.
Jeff
dave
Is the 1/2" stuff the radiant barrier that comes with a aluminum foil backing, actually 3/8" thick.
- Full Range
- Fonken cut list and damping material question
