Folsom EC7293: Battery/Solarcell Powered Feedback, 60/120w
Seen your prototype and thinking of assembly of amp boards to each side of case with integral heatsinks. Mirror image of amp boards would be advantageous or is it possible to populate either side? Also helpful would be overall dimensions of fully populated boards.
Martin.
If it fails nothing bad happens. The amp just won’t sound good. Also the LED circuity on the bulb doesn’t engage because of our regulator for it. They could last longer than any LED bulb for house use. LEDs are suppose to be good for 25 years but the circuit in the bulb usually isn’t, but in this case it isn’t engaged.
It wasn’t a “choice”, the circuit needs the stability, and no one liked the battery option. The only other alternative is bad performance or ICs that aren’t the same necessarily in outcome.
