Ok, This should be simple question, i know little about optics
when trying to make compact projector and dealing with the focal length of the fresnel, does a mirror setup effectivley increase the focal length of the light source??
like:
fresnel
|2cm
| 3cm
\ <-------------- ) light source
mirror
does this make the total distance from fresnel to light 5cm??
I only assumed this is how it works, because projectors are so compact with mirrors, and most fresnel's i find have like a 14in focal length. thanks!
like:
fresnel
|2cm
| 3cm
mirror
The focal length will be the distance to the light, so if you use a mirror, yes, it will be longer.
50joe said:Ok, This should be simple question, i know little about optics
The focal length is static, so if you use a mirror it will not change. The mirror allows you to modify the shape of the case into a shorter and wider design, rather than having a tall rectangular box.
BT
