does anyone here know where to find the T/S parameters of the Focal 8P511 unit?
It's a pretty old unit (about 18 to 20 years). A friend of mine got 2 of them from another forum-member (THNX for that) and he couldn't find the T/S parameters. I looked over about 50 Klang&Ton's but i couldn't find it also. (google.com doesn't give any results also)
Who can help him out?
Thnx!
Grtz, Joris
Thnx!
Grtz, Joris
I have an old Focal brochure which mentions a kit that uses the 8P511 (KIT 430). Unfortunately there are no T/S parameter in the brochure.
I also have an old Remo (88/89) brochure with some specs of the 8P511:
210 mm (outer diameter)
176 mm (mounting hole)
85 watt
92 dB/w
29 Hz
Qts 0.21
VAS 109 liter
BL 220 * 10^-5 Wb
2.6 kg
89 mm (hight)
85 watt
92 dB/w
29 Hz
Qts 0.21
VAS 109 liter
BL 220 * 10^-5 Wb
2.6 kg
89 mm (hight)
Hi Duck,
thank you for your reply, I've had another list in my mail.. that makes a total of:
Fs 29.1 Hz
Vas 107.7 / 109 Liter
Qms 3.82
Qes 0.26
Qts 0.24 / 0.21
BL 220 * 10^-5 Wb
Pe 85W
Sd 220cm2
Vd 60.5cm3
n 92db/1W/1m
210 mm diameter
176 mm mounting hole
89 mm high
The only things left are Rdc an Le... hmm... maybe someone alse knows the last parameters?
Grtz, Joris
Fs 29.1 Hz
Qms 3.82
Qes 0.26
Qts 0.24 / 0.21
BL 220 * 10^-5 Wb
Pe 85W
Sd 220cm2
Vd 60.5cm3
n 92db/1W/1m
210 mm diameter
89 mm high
Grtz, Joris
I seem to remember suddenly that those speakers were used in Focal Kit model 400. Indeed about 18 years ago. They were sold to me by a guy called Charles van Oosterum. He is the one most left in the picture http://www.kharma.com/-g-ols/a-f-ols.htm (click Manufactory)
I never tought I would make someone happy with such an old speaker. I hope he makes something nice out of it!!🙂
Jan
Jan
Hi Jan,
He's very glad with them!! Tony Gee told me he has the complete datasheet of the unit, and he will e-mail me all the info today... so I'll wait ... If he can't help me, I certainly will contact Charles!
And BTW...damn...those Thel's sound GOOD!
Grtz, Joris
Grtz, Joris
- Focal 8P511 T/S parameters
