Joined 2009
You don't want the Cornu's for close range, and they don't have the dance music bass either. They actually seem to work best when you are about at least 7 ft away, preferably more like 10 ft. They are not flat (based on the reviews) and the models so far. You wouldn't want them for studio monitors.
Any updates on near-field use? I was thinking of a small pair for a very small office where listener is only 4' away sitting at a work bench.
I made a 14in pair and used with 2in drivers for my office and they worked well at 4ft away. Not much bass below 100hz but that was fine for the office.
Hello xrk971,
do you have a Karlson design or a good design suitable for an Alpair 12p full range driver?
I'd like to try it.
Guglielmo
I'd like to try it.
Guglielmo
Let me work up a Karlsonator or XKi for you. Give me a few days - do you have preference for deep bass or more general use with higher sensitivity?
Hello,
I've only 8W so I need high sensivity and deep bass.
Can you make a miracle for me?
I belive in you.
Ciao
Guglielmo
I belive in you.
Ciao
Guglielmo
xrk971, how do you do straight cuts with xps foam? I'm thinking about making some kind of alignment tool for knife blade as xps is much thicker than foam core.
It turns out that xps is dirt cheap compared to hobby store foam core and as an added bonus it's just slightly thicker than mdf/bb, so the prototype size can be nearly the same as final speakers.
Use a new break-away blade utility knife with a deep enough blade that can cut through. I buy mine in 3 pack from dollar store.
Put XPS on carpet floor, use a long piece of hard material like Masonite for a straightedge. It should be wide enough so you can use your hand to easily apply pressure to secure it and keep from wiggling during cut. A skinny metal ruler is not as good as it has too little contact area to hold steady.
Start cutting using straight edge as guide and keep blade vertical. Do 4 to 5 cuts each time deeper. Do not try to do in 1 or 2 strokes. A sharp blade is essential for clean edge.
Why on carpet? It protects blade and gives room to cut through and allows your body to be positioned above work piece to ensure straight vertical down cut angle.
I like the carpet because it helps build up a static charge and that's always fun when you're holding a really sharp knife. 🙂
OK, Now I know what it is. I use the 1 inch size for the base of my model railroad. Never tried it in a baffle.
Ken
Ken
Hello xrk971,
do you have studied a good design for my Alpair 12p full range driver?
I'd like to start to build.
Any suggestion of a good foam in Europe?
Thanks for your patience.
Guglielmo
Guglielmo
Larger drivers generally require larger boxes so keep in mind you will need a lot of bracing. Xps insulation foam is more suitable for larger projects.
Hello xrk971,
Guglielmo
The Alpair 12p has some known frequency response anomalies compared to it's factory published curve. However, perhaps in a similar way to the CHN-70, placing it behind a K-aperture in a Karlsonator will cure the issue? In any event a Karlsonator is excellent for deep rich full bass without baffle step loss.
Here is a sim I did of Alpair 12p some time ago:
http://www.diyaudio.com/forums/full...sonator-0-53x-dual-tc9fds-80.html#post3956297
This is a Karlsonator 8 (or 8/12 scale Karlsonator).
I searched for cardboard boxes after building quick sealed enclosures (I first did that as a kid, now I'm surprised they sound good) for my new cheap chinese 5" 60w 4ohm speakers (Silverton TS-1300, couldn't find their T/S params :/ ), and stumbled on this thread, diyAudio never disappoints me.
As far as I read, I'll only scale the Cornu design to fit my speakers. I only found 17mm thick popcorn foam (popcorn = expanded polystyrene which is EPS not XPS, XPS is extruded polystyrene ).
The plan is to lay the spiral with cardboard (since it's flexible), and the sides with the thick EPS. Are there other forgiving designs like Cornu or just build a sealed big tower and call it a day (I'm considering the BIB, but that needs some T/S params if I recall) I might do T/S measurements for my speakers at a later time.
Years ago, I built a pair of speaker enclosures using 1-inch thick Styrofoam panels and Elmer's white glue. The drivers were 8-inch Polyplanars (also Styrofoam) so there was a certain logic to the combination. The glue worked great - best joints among panels I have ever attained - but, not surprisingly, the panels exhibited far too much resonance and muddled the sound. It was a quick and easy project, though.
- Full Range
- Foam Core Board Speaker Enclosures?
