FM portable radio
I, new here and sorry for my poor english, I, was wondering if a High quality portable FM radio does exist! I'm actually using my HD Zune FM radio (with cMoy v2.03 & Atrio M5) at work, but must often listen to music unstead because of bad frequency & high distortion. I'm a cMoy v2.03 portable amp user and read a lot about portable amp, so wonder if FM portable exist?
Thanks,
E-Audio
Since almost all these portables use the headphone cable for the antenna, have you tried different interconnects between your Zune and cMoy? The reception of my Cowon J3 's FM tuner depends on headphone model for example. Before buying something different you might want to try experimenting with an unshielded interconnect made from lightly twisted wire first.
what about this tool:Tecsun PL360 Digital AM/FM SW Shortwave Portable DSP Radio
Frequency coverage:
FM: 87-108MHz;<br>
AM: 520-1710; <br>
SW: 2300-21950 KHz <br>
Sensitivity
   FMS/N=30dB<3uV
   AMS/N=26dB
< 1mV/m
   ShortwaveS/N=26dB
< 30uV
Selectivity:
   FM
60dB
   MW/LW
60dB
   SW
60dB
FM stereo crosstalk
< 25 dB
Output power: 350 mW
Memory
450
Speaker
Φ40mm / Impedance 16Ω
Earphones
Φ3.5mm/32Ω Stereo
Power supply
   Batteries3 X AA
   AC/DC adapter: USB 5V/300mA
actually using Fiio L2 interconnect, with Atrio M5 earphone, but also connect my desktop M40 Audio speakers with ''Monster TRS 400MKII'' to cMoy and ''Qed Performance J2J or Fiio L2'' to Zune(same results). Depending where in the building, I may have no FM reception at all, like if I was too far!
200$ earphones..??...
How long is the jack cable ??..
The phone cable must be at least 75cm long , wich it surely is
but a multiple of this number would be even better , let s say 1.5 metre....
Close to...next earphone will probably be VSONIC GR07!
Interconnect Fiio L2 cable is short, but I've tried also my 1.5M Qed Performance J2J with same result.
FiiO L2 specs:
Length: 10cm (cable only)
Weight: 10g
Wire Diameter: 4mm
Wire Model: HPC-22W
Wire Material: PCOCC-A
Impedance: Max 0.1 Ohm
Insulation: Min 2M Ohm
Wire Jacket: TPE
QED Performance J2J specs:
- 3.5mm mini-jack to 3.5mm Minijack Cable
- Electrical shielding for superior interference immunity.
- Precision engineered plug with integrated grip
- 99.999% Oxygen Free High Purity Copper Conductors
- Coaxial design for enhanced signal transfer
- Unique 24K Gold Plated 3.5mm Stereo Jack
As for climbing in society, I will have to buy it😀
Try a portable radio built in the 70's. One with an actual dual-gang tuning capacitor. Digital tuning receivers are notorious for processing interference. E
ps: What's wrong with earphone? An audiophoole and his money....
I'll see for the portable radio" As per beeing an ''audiophoole'', please elaborate. For now, this Atrio 5 earphone is best I had and I've tried couples(value sound-money for what I can afford...and deal I had)!
