If you are talking about a bias supply, then there is a vague possiblity... the open circuit voltage for most of them is ~600vac, iirc.
It's not really required, since you can use a simple diode multiplier stack to acheive almost any HV you need to bias an ESL, no significant current is needed.
At least one manufacturer used an AC "wall wart" and a reversed small step down transformer followed by a diode multiplier for the HV bias... resulting ~5kvdc.
To drive an ESL with audio you need a high quality transformer, often people use an appropriate impedance ratio output transformer driven "backwards".
_-_-bear
_-_-bear
