I've got a Fluke 175 that works ok but---
Turned it on and battery was dead.
New batttery and it seems to have lost the beep function although everthing seems to work as it should.
I tried using the start up option to turn off the beep thinking it might resest everything to no avail.
Anyone ever have anything similar or have a solution??
😕 Thanks
😕 Thanks
You can find service information on those units on the web. I don't recall if it's on the Fluke website or where.
I have a Fluke 175 that lost it's beep, too. It was under warranty and it was fixed with no problem since.
Lots of problems with series 175 as i see,i own a 175 too , today i send it in service 🙁 ,a software bug i gues, the only way to power it on is to disconect and reconnect the battery (rotary swich position other then off). Other way mastech my68 after 4 years(hard work) have no problem !!!
Thanks for all the info folks.
I'm sure mine is still not under warantee so I guess I'll live with it.
I've checked the Fluke site for workaround but no luck.
Thanks All.
Thanks All.
