I've seen this topic raised before but have since seen some manufacturers that throw the general rules out the window.
I've always had a height of about 100mm [4 inches] off the floor in my mind for no other reason than a hunch.
Some REL subs have a mere 50mm and some of the feet you can buy for subs range from 50mm to 150mm or if you want to add furniture legs, as high as you want.
Is there any golden rule apart from it being high enough to stop the driver not bashing into the floor!
