Floating Transformer Technology
*So it is stucked here, I would like to see some schematics and *I'm still querious what it is electrokompaniet does.
*How do they calculate the amount of capacity?
*Or is it just a sale frase?
*/Magnus
Please see my post #25. EC FFT is explained there.
Noize.
Dear Jan and Magnus,
You are discussing the amplifier with small switching distortion, when a low-power class A amplifier is connected in series with a high power class B amplifier. The technique is at least 25 years old:
N.Sano, T.Hayashi, H.Ogawa,"A high-efficiency class-A audio amplifier", AES preprint 1382, 1978
Why do you name it FFT (floating transformer technology)? Can you read Noize post?
Dimitri,
You are absolutely right. This is not FFT. The circlotron, discussed in tons of posts on this forum, is. So is the tube version called PPP (parallel push-pull). In each case you have like two SE amps, each with a load which is in the cathode (or emitter or source) lead, the amp element (tube or ss) and a supply in a loop as always. Each set is driven in opposite phase. The trick is that the load is connected between the two cathodes (emitters, sources...). So, each side of the load also moves the suplly up and down with the outout signal, hence the name. Try to draw it, real easy.
There's one caveat: the circuit needs a ground reference for the driver stage, so mostly you see the midpoint of the load grounded, either by two resistors across the load with their midpoint grounded, or a choke with a midpoint tap grounded across the load. Probably many other solutions I'm not (yet) aware off.
Jan Didden
Don't know whether it's of any use to you but here's a drawing of the operation principle of the circlotron aka the Wiggins amp or bridge amplifier.
This one in particular is an OTL but you can just as well use an OPT.
Cheers,😉
Hi Jan et all,
But there must be a ground reference somewhere on the output stage, yes? Like middle of the load?
Exactly.
And that's also what I don't like about them; in the case of an 8 Ohm speaker virtual ground would be the midpoint namely 4 ohm either side.
With an OPT this isn't a big deal though...
Cheers,😉
Thanks,
Yes I read "noize" post and realize that it isn't FTT and I have read alot of the circlotron posts the last two days with much interest.
Now I'm more curious of, how electrokompaniet calculate their caps, they say that less is better, but I don't think nothing is the best.
/Magnus
I would think the size of the caps (capacity) should not change from a " normal" circuit or a circlotron. You look at the supply voltage, the load current and that determines as ususal the capacitance.
Frank: In the (very) old days I built these amps with 800 Ohms speakers, the Philips 9710 series. It was easy to get a small choke with midtap (or two chokes in series), and put that across the load. With an 8 Ohms load, I think 2 x 100 Ohms or so should do the trick. It's basically a DC reference you need.
Jan Didden
Fred,
All the transformers I have used were heavy enough to sink like a rock.........
That's because you earthed the midpoint...
Jan,
He,he...my cousin had the Philips 800 ohm (AD something) , I had made the amps.
Every school holiday outside the big two month "grote vakantie" the amps and Frank travelled to Amsterdam.
You're correct about the resistors, for some odd reason they never appeared on the original Wiggins. Probably because they used high Ohmic speakers as well? I dunno.
Cheers,😉
Ah! But that's where those xformers with wood cores come in. Also have much lower eddy current and iron losses.
They're very poplar in Holland, often made out of old "klompen".
When highly oversized you can even cross the Amstel with them.
Cheers,😉
Wil Blauw winding poplar cored trannies:
