Ok thanks I will keep that in mind if it decides to break.
2 2fast4u88 Member Joined 2010 2010-07-02 5:42 am #21 2010-07-02 5:42 am #21 Ok thanks I will keep that in mind if it decides to break. ••• More options Share B brandes.cm Member Joined 2009 2010-07-02 12:52 pm #22 2010-07-02 12:52 pm #22 The pot you are looking for is Bourns PTD901-(1or2)-0(shaft length)K-B(ohms). The parts in parenthesis need to be filled in by you. The resistance of the pot can be measured if you don't know it, They don't offer a 30K pot. cory ••• More options Share Prev 1 2 First Prev 2 of 2 Go to page Go Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button.
