Fishman Loudbox Artist - help
Dear all, I found this amp and only the headphones output works, not the speakers. I can't find out how to open the "bottom" enclosure, which contain the power board/transformer and the main amps I believe (Bi-Amp). This video (not mine) of its baby brother shows c;clearly the same design YouTube Anyone knows how to open the bottom? A schematics would be great - I understand they cannot be posted here but a [private message would be highly appreciated 🙂
THX for any advice
Nope, it is the top, or chassis which contains all of the electronics, three screws either side and the chassis lifts off.
Access to the loudspeaker cabinet as such, remove the woofer and you can access the cabinet interior.
Schematics are attached.
Kevin
Thanks a lot Kevin. As I replied on the other thread - the schematics seem to be for another model, not the "artist"
Did you intend to attach schematics to this message?
Dear all,
I spent some time drawing this schematics for the main board. Lots of fun (first time I'm doing that!) , obviously lots of errors/incorrectness (I didn't do a proper set of hierarchical sheets ; not sure if my global labels are the proper way to do that ; R values are a bit all over the place🙂
R1 looks weird. (see my other post). Would a burned resistor measure a higher value than its nominal? If not, why would it be one order of magnitude higher resistance than its three siblings R32 R33 and R34 ?
THX
Dropbox - PDFs - Simplify your life
