Hi All,
I have a fisher DAC-9335, 24 disc CD changer. My son blew the speakers on the stereo a few years back and it has not been used since. Last week I got new speakers. When I hooked up and turned on the stereo the CD changer worked. I loaded a CD and played it to check the system. Then when I went to load more CD's an "m-error" message scrolled across the screen. The manual said to reset the system by unplugging the power cable and plugging it back in. However, it still will not load or unload CD's and the "m-error" message scrolls across the screen.
I have one CD in the number one slot and it plays but that is it. As soon as I try to load, I get the message.
Has anyone run into this problem before. I would really appreciate any help.
Thanks in advance,
Rodder
Thanks in advance,
Rodder
disc CD changer
You need to open up the changer and find out the condition of the rubber belts in the mechanism.
Gajanan Phadte
...blew the speakers on the stereo a few years back and it has not been used since.
Gajanan Phadte
Lolll!! The rubber belt!! We can clearly see that you're talking through your hat as there's NO BELT into that model and also ALL the Fisher 24 disc changers. Instead, you have to change two idler gear, one is located near the front of the unit, where the loading mecanism is, and the second is where the loading disc is, near the bottom left of the unit. Those two idler gear are not expensive but this is quite a job to change them as you have to lift up the whole mecanism. Good luck!
