Hello Everyone,
I've been reading on this forum and the klipsch forum regarding a diy la scala build. I have read many opinions on the klipschorn, la scala, jubilee, belle, voltis. Even some jbl builds, m2, 4350.
I plan on running an active eq/crossover, and an active powered t-line sub.
It seems a 2 way sytem is very popular (1 horn 1 bass bin), I will go 3 if you guys suggest.
I need some advice.
For the top should i go klipsch k510, k55m, or jbl 2430k D2?
D2 Dual Diaphragm Dual Voice Coil Compression Driver
KLIPSCH LA SCALA TWO K-55-M HORN DRIVERS PLUS HORNS !!!! | eBay
What driver, what horn?
For the la scala bass bin, what driver? Jbl or klipsch/Crites?
Envision 3 stacks, sub box same shape as la scala, la scala stacked on top sub, compression driver on top of that. Modern looking la scala sitting on top of sub.
Thanks for the advice.
I need some advice.
