First time designing crossover
hi,
I have pretty much zero knowledge in how to build a crossover, i've been watching some videos and messing about with xsim with a few speakers online just to test the waters.
Just want to know if this looks right and if i'm heading down the right path?
Many Thanks
22 mH in the tweeter circuit seems like a red flag also.
Starting off with some textbook crossover component values is helpful. You can use an online calculator for higher order crossovers, or use XSim's built-in circuit blocks for 6 and 12 dB/octave crossovers. These values are typically adjusted once real-world impedances and frequency responses are involved, but they give you a general idea about the typical values to expect for a given impedance and cross point.
hi,
Many Thanks
From looking at the fr response you provided, you selected 70Hz and 2kHz crossover points. Why?
First, 70Hz seems rather low. Its a subwoofer territory. You select such a low crossover point, if you are planing to place subwoofer in separate box further from mid and tweeter. Otherwise such low crossover point makes no sense.
Typically starting point is 300Hz and 3kHz, but this should be selected based on actual drivers, where they are starting to beam. That is on axis and of axis behaviour.
I assume you have not selected the drivers yet.
This page can help you to understand a bit about crossover design.
http://www.troelsgravesen.dk/Diy_Loudspeaker_Projects.htm
Reactions: picowallspeaker
