Hi there, i'm trying to make a L+R summer with LP with the least components possible, which also provides the original L and R reparate channels with HP.
Despite both circuits need some adjustment to get the -3dB point coincident, i sort of get what i want, but when i connect both things in parallel to the AC generator the filters go mad. It may be an awfull abomination but this is as far as i got, is there an easy way to isolate both circuits if they share the signal, or my attemps are worthless altogether?
In the pics u ll see the buffer for the L and R with HP and the L+R and then the awfull altogether stuff. Besides adjustmets, it just fails to work altogether when joined:
Here just the LHP:
Here the L+RLP: (incredibly DC is at about -2.5V)
And here the little frankenstein:
Here just the LHP:
The power amps will load the filters somewhat, and may reduce gain and shift frequencies.
Adjusting the R and C values appropriately should be able to work well enough.
For discrete BJT circuits, I've always used the emitter bias type. Wikipedia has a good description:
https://en.wikipedia.org/wiki/Bipolar_transistor_biasing
didnt knew wiki was so clear in this topic! thanks again! interesting, we are encouraged to use the emitter bias at the uni, i ll give it a try for sureThe power amps will load the filters somewhat, and may reduce gain and shift frequencies.
In class today we saw the emitter bias for AC without the bypass cap on Re --> turns out, now i have two separate current generators with just one transistor, and all is independent from Hfe or other related transistor hybrid parameters. Still have a couple of months to adjust, but it seems promising.
- First project --> BJT adder for subwoofer with embeded crossover
