Finished powered speaker set. Pickup in SoCal
From time to time I build a technology demonstrator for a concept I have in my head. This is a pair I was working on to learn active crossovers and finished with what I needed. I designed a passive crossover to work with the internal amplifiers thus creating a powered pair of speakers that will work quite well for someone. If you just want nice speakers, they will work today and work well. If you want an all out killer reference you can tweak the crossover to perfection and blow away $30k monitors. These are great for someone who doesn't know how to use or doesn't have access to expensive toys like vertical machining centers and cnc routers.
The parts are as follows:
Scan Speak Revelator 18W/4531 G00 Woofers
Scan Speak Illuminator D3004/6600 AirCirc Tweeters
Hypex MP250 N-Core Amplifiers 1 per speaker
Hpex HF100 NCore Amplifiers 1 per speaker (not being used in passive configuration)
Various connectors, switches, and custom PCBs for power switching and aux power for optional active crossover.
CNC machined rear aluminum plate
CNC cut wood parts
Rift white oak veneer
General finishes professional line satin poly finish (sprayed)
Extra ports of different lengths so you can tune to your liking.
I will also include a crude active crossover for these, and the design files, both for the PCB and the VituxCAD files.
These are for local pickup only in the Orange County, CA area. No, I won't part them out. No, I won't ship. No, especially not overseas. Yes, that means for you too, even though you asked nicely.
Price is $1000.00 I can entertain a VERY limited demo in my garage to ensure functionality.
