Finished 2 ways..... mixed result
mass.com
mass.com.au are great though, I have bought two lots of drivers from them, one lot I needed within 2 days so I could tinker across a long weekend..... I had them in under 24hrs - Perth to Brisbane.... damn good service....
highly recommend them (Australia)
lee
phase_accurate said:
Justa little hint: If you forget to hammer the T-nuts in before attaching the baffle (or if there is any other reason to do it later) you can screw them in using a screw from the front side. Be sure to use someting to prevent the screw's head to be pulled into the wood. I usually use a flat piece of metal with an appropriately sized whole in it. You also have to grease or oil the screw a little, but make sure it's not too much.
I've always done it that way. And when done with a electric screwdriver, it's real fun. 😀
