Hello, out there. We have a M &S System MSC3/4.
We have Model MC960PA power amplifiers powering 45 ohm speakers from an older intercom system.
The problem is the old amps are being overpowered by the more powerful signal from the new master units.
Are there any power amplifiers in the market which I can use to replace these MC960PA's?
Bart aid@thealamo.net
New amps designed for 45 ohm speakers?
You say your 960s are being overdriven at their inputs? Do the amps work OK and sound OK if not overdriven? If they do, why not simply add some attenuation between the master units and the amplifiers? A "pad" or even as volume control. That is a heck of a lot less money than new amplifiers.
