Does anyone know a make/model on an crossover that will handle 1 hp, 2 bp, and 1 Lp, crossover settings?*It will be used for my tweeters for HP, my front and rear mid range speakers for BP, and subs for LP. My budget is under $100
Try the following:
Assembled Passive Crossovers in the Speaker Components Department at Parts Express | 308
You're not going to find a single crossover that does what you need but you should be able to use the various HP, LP and BP crossovers to achieve your goal.
