Just received my Audio Sector LM4780 kit, and am looking to assemble all of my parts to begin.
I will be ordering heatsinks, wire and rca jacks, as well as pots. When I do so, I have several questions.
1) How would one wire mono pots into the circuit to control the levels of each channel independently?
2) When selecting heatsinks, what is the minimum requirement if I intend to run this with 4 or 6 ohm loads and running a 22v or 25v transformer and upto 160w @ 4ohm?
3) I have read the thread on assembling a power supply, but my kit comes with the rectifiers etc. Is it okay to fuse the transformer at the mains in and connect the transformer to the rectifier board and onto the amp boards! I noticed a "shaded" area in the Power Supply tutorial, but am not sure what I'm supposed to follow.
I intend to order heatsinks, and be a bit resourceful in finding an enclosure, rousing different materials. Other than that there is a lot of information in threads that address some questions, but I've had trouble finding answers to the ones above. Thanks
