After many years of trying to make PCBs and only having limited success, I finally found this product that works straight out of the box and is clean and easy to use.
PCB Fab-in-a-Box Kit — Cool Components
It relies on the same toner transfer principle that is commonly advertised but uses a clay coated paper that guarantees 100% of the toner is transferred to the board.
The producer acknowledges that the toner image may not be 100% opaque and addresses this with a Green Foil that ensures solid traces from a less than solid toner image.
Top up paper and foil is readily available and won't "break the bank".
Results are better with the recommended laminator but I did get good results with a household iron.
It's well worth the money in my opinion.
