Finalizing TDA2050, LM3886
I posted a spreadsheet that will simulate a linear power supply with the worst-case load, with variable transformer ratings, reservoir capacitance, load resistance, rated output power, and basically everything else you need, which is attached to the post at:
http://www.diyaudio.com/forums/power-supplies/216409-power-supply-resevoir-size-167.html#post3287619
It uses a numerical solution of the differential equations for the circuit. So no approximations are used.
A downloadable PDF file describing the spreadsheet, and the solution method, et al, is attached to the post at:
http://www.diyaudio.com/forums/power-supplies/216409-power-supply-resevoir-size-166.html#post3279883
However, I recommend using LT-Spice, since it is much more flexible and powerful. It is a free download from linear.com.
Tom
Question to you guru's if I may.
On the website of TI they show an SMD version of the LM3886, see pic.
But none of the usual suspects have them in their catalog.
Anyone seen one of those, or know where to get them?
tia, jan
tia, jan
If they don't offer samples, can you simply make some by bending the pins of a through-hole version into the correct positions? Or do you need some "real ones"?
