Final Stage of Building UcD400
Hello,
I'm now finishing my UcD400 amp recently bought from Hypex Electronics, I've noticed from the manual that there is an /ON (on internal pull-up) pin on the 4-pin connector, to be connected to the supply ground to a switch...
What will be the different between opened and closed switch for this signal?
Thanks,
RR.
Hello RR:
This pin must be connected to ground to power-up the module. Open switch will power-down it. I think it's a very useful tool for delayed start, when PS is stable.
If you have multiple modules it is recommended to make all "ON pin" wires of equal lenght.
Am I wright?
Hope this helps.
Best of lucks. 🙂
M
