A friend decided to clean his car's interior one day.
I don't know if he used an abrasive pad or what, but now one of his car readouts is all foggy and scratchy looking.
The dealer, (not under warranty), said he would replace the plastic faceplate for $150. A tad steep, my friend thinks, (and I agree).
He wonders if there is not some substance that can help this. I asked him if it momentarily gets clear when he wets it and he says yes. So I think there probably is a substance which can fill those scratches satisfactorily.
I have seen casting resin, which I linked to right here.
However,it seems to come in fairly large packages, is somewhat expensive, (not too bad), and might constitute overkill.
Anything in a tube smaller or easier? Is there anything which fills in the scratches in plastic eyeglasses?
Have you tried Meguiars Mirror Glaze? The other thing to try is that stuff that comes in a toothpaste tube used to cover up car scratches- it's a mild abrasive with carnauba wax.
SY said:Have you tried Meguiars Mirror Glaze?
No, but I certainly like the sound of the product. Is that available in hardware stores or must I go on the net to buy?
I will try that, although I don't think his faceplate needs more abrasion. But I will try the Mirror Glaze product first.SY said:The other thing to try is that stuff that comes in a toothpaste tube used to cover up car scratches- it's a mild abrasive with carnauba wax.
If he has scratched it too harshly then more abrasion but with a much finer grit will probably help, as it will take some effort but will rub the surface down to nice material again.
The products suggested so far will all achieve this.
There are numerous products on the market that can help. Try one of the many "headlight restoration" kits out there.
http://cgi.ebay.com/ebaymotors/JANV...ategoryZ6755QQihZ013QQitemZ230096364076QQrdZ1
http://cgi.ebay.com/ebaymotors/Clea...015QQitemZ250089285841QQrdZ1QQsspagenameZWDVW
http://cgi.ebay.com/ebaymotors/REST...tegoryZ50450QQihZ014QQitemZ330092111023QQrdZ1
Tom,
phys and chem say that's possible, but experience says it takes a REAL craftsman - nothing I'd try at home. How come you know people like that - they are becoming an extinct specie!
Pit
Pit
The Meguiers Mirror Glaze works very well. Auto Zone and Advance Auto should have it in stock. The Meguiers Color Rx also works wonders too. I've even salvaged chewed up Netflix rental DVD's with it!
Again, thank you for all your responses.
I only mentioned the suggestions here once to him, and he sounded like it was a good idea. I'll mention it to him again this weekend, might even end up giving him a hand with it.
Meguiar's was mentioned a few times, and AutoZone is only two minutes from his house, so we'll give that a shot first. Though the toothpaste bit sounds intruguing.
- Member Areas
- The Lounge
- Filling In Scratches In Clear Plastic Car Dial
