Source is the output. e.g. CD player line out is the source/output, pre-amp/amp line-in is the input.Gabdx1 said:Input end / source = I thought they were the same, correct me if i am wrong, please.
What I mean is to ground the drain wire at the electric source.
For interconnects I just don't understand ! For me interconnects are the connecting wires that link one module to the other ex: cd player to amp.
I would call ptp wiring the wires inside a circuit, or simpler just wires... Is it just me?
zigzagflux said:There is a more subtle reason, though, even for tubes that have their cathodes very near ground potential. The idea is to 'bias' the heater voltage to a positive DC reference voltage with respect to the cathode. The goal being to keep the heater voltage always positive wrt the cathode, preventing a pseudo- forward biased diode behavior. This has been known to decrease hum when using AC heating (and possibly DC heating, IDK). This DC reference should have a reasonably low impedance to ground from 5Hz and up.
Got it, thanks.
I imagine the mechanisme at work is like a vacuum cleaner, sucking up free electrons between heater and cathode. Or did I drink too much coffee right now? 😉
