Does anyone have an opinion on whether it would matter if the resistor used for filament bias needs to be non-inductive. This design uses a 6 ohm resistor at 35W or so. I could do 3 Mills 12 Watt, 18 ohm in parallel or a Dale 50W 6 ohm silicone covered wire wound. Any thoughts on that?
It needs to be the correct value to get the voltage right. Inductive, non inductive, carbon composition, metal oxide. makes no difference. when induction is concerned unless there is no decoupling capacitor and it is for RF amplification, because the induction it too low to make a difference.
And it is for the heaters, not the audio signal path. My heaters don't worry too much about frequency response.
That was my logic, but wanted to make sure. I have some Dale wire wound 50 watt resistors and wanted to make sure that I could use them even though they were "inductive". I am running DC on the filaments and thought it would make no difference.
actually its for the filament which is the cathode in a DHT, so it is 100% in the signal path
Ah, then you are privy to details of his project that I am not. I have no idea what circuit he is building. I had assumed for discussion he was planning for the very common DC elevation of heaters for hum abatement.
- Design & Build
- Parts
- Filament Bias Resistor
