I need an extension an wanted to be sure to buy the right one...
here you can find a picture of the cable JPG. It seems to be a 20 pin (cause of numbers of final solders near the zif socket) and a 0,5mm pitch cause of his width of approx 1 cm.
Can you confirm it? thanks.
curiosity: the lcd is a Nfren 151m4, my friend and I bought two units from the same store. Same model, but one is totally FFC issue free and mine has the problem above
So this panel is both projectable and not, depending on your luck picking the unit.
